Whirlpool french door bottlm freezer not making any noise a
My whirlpool french door bottom freezer had its control board replaced and now will not stay running i have to switch the breaker off an on to get it to start putting out air. It then stops and the fridge and freezer are not reaching temp. Also not making any noise. Control panel is on set to highest settings and it isnt even close. Tired of this its cost me over $500 in food loss the pst two weeks alone. The freezer is not iced up in the back, the fridge is barely cool after it runs when the breaker is flipped off and on it runs maybe 15 minutes. Then is silent. Please help obviously the repair guy is an idiot
Es esta una buena pregunta?
Hi @mrsjareth,
What is the model number of the refrigerator?
How long does the compressor run for before it stops and won't start again, unless you reset the breaker?
- de jayeff
I would check the thermostat. Find the end of the temperature probe, and hold it with your hand to warm up. See if that does anything. Check with multimeter to see if voltage is coming out of it to activate the compressor
- de brandon k
@mrsjareth you mentioned that "now will not stay running" that suggest it did keep running with the previous control board. Is is correct that those symptoms just started with the new control board? What Model is your fridge?
- de oldturkey03
