Saltar al contenido principal
Lanzado el 4 de noviembre de 2017. Modelo A1865, A1901. Disponible como GSM o CDMA / 64 o 256 GB / Silver o Space Gray. (Se pronuncia igual que "iPhone 10.")
Preguntas 1198 Ver todo
Why does the inside of my iPhone x look different than everyone elses?
i just bought a new screen to change on my iphone x. I opened my phone and ran into a problem - it seens to have a bracket around the edge that no other iphone x’s have? here is my phone:
here is what everyone elses phone seems to look like online:
looks like i have a different styled iphone x, however everything online only says there is 1 screen and 1 original design. anyone know whats going on here?
Es esta una buena pregunta?
Puntuación 0
1 comentario
Did you ever figure out the issue... I am having the same problem
- de
Agregar un comentario
4 Respuestas
Solución Elegida
That bezel part was supposed to go with the screen, however it was torn from the screen and stuck on the phone.
That’s it, easier than you think.
Fue útil esta respuesta?
Puntuación 5
6 comentarios:
but why do that?
- de
@Landon Hage why do what?
- de
why put those parts in the phone instead of on the inside of the screen?
- de
@Landon Hage Because that's part of the screen, not the phone body.
- de
Oh, so does it just make the repair easier. Like replacing less parts?
- de
Mostrar 1 comentario más
From what I can see the iPhone X has the little site clips on the end of the screen
however, the iPhone XR and XS do not have the clips on the end of the screen
what is your phones model number of the phone
Model numbers: A1865, A1901, A1902 for iPhone X
so it looks like when you have opened your phone the side clips have detached from the screen have a look at you old screen you have removed and you will most likely see where it has come off
Puntuación 3
2 comentarios:
mine is the A1901
- de
you guys are the best thank you
- de
For future reference, I've copied the relevant information from my post on the Italian site to here for the next time this issue comes up again.
Okay, the thing is, this is a standard iPhone X. The problem here is that for some reason the adhesive that holds the frame that is supposed to be on the display has failed, so when the screen was removed, all that came off was the LCD, leaving the mounting frame and the plastic front camera holder inside the phone rather than still attached to the screen as they should be.
I believe this is probably caused by failing to remove the two Pentalobe screws next to the charging port before removing the screen. If that's the case, the LCD frame would remain locked to the case and this would be the result. I would imagine it's a lot more difficult to get the LCD off than it should be in that case.
I've marked with colored arrows where the parts are vs. where they should be on the display.
Anyway, what has to be done now is to remove all those parts I marked on the phone. If not already done, remove the Pentalobe screws! The bottom part of the screen frame cannot be removed without taking out those two screws.
Use something thin to slip between the display frame and the phone frame and follow the screen removal instructions to cut the adhesive all the way around. Once that's done, it should be simple to lift all of those parts away from the phone's frame. Flip them over and lay them on the old screen to see how they should look.
Remove the earpiece speaker assembly from the old plastic mount and follow the earpiece speaker guide to reinstall it onto the new display. After cleaning the old adhesive from the case and putting on new precut adhesive. everything should be ready to reinstall the screen. Don't forget the Pentalobe screws.
Puntuación 1
Hi, I have the same problem. I ve to fix my phone but, all display on amazon are with the clips. What can I do? I cannot find a display withouts clips
Puntuación 0
2 comentarios:
Pry the clips out of the phone and throw them away, then put on a display that has the clips. Once the display is off, the only thing holding them in place is some adhesive and small retainers along the sides.
- de
@dadibrokeit hi, can you please check my post? that's what im talking about :https://it.ifixit.com/Risposte/Visualizz...
- de
Añadir tu respuesta
Spencer Lott estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 438
