Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Replaced Front Face Assembly, Touchscreen Only Works When Opened
I replaced the touchscreen on my iPhone 6 about a month ago (actually, the whole front assembly) and it (the touchscreen) will be responsive when my device is open. But, whenever I put back the screws and cover plates and close the phone, the touchscreen is unresponsive. Over time, I opened it multiple times, replacing the screws, one at a time, to see if that was the problem. Nope. Same problem. When open, it works; when closed, it stops working. Frustrated, I put the phone away. Yesterday, I opened the phone and moved the screen a bit without disconnecting anything (not the cover plates or the cables) and the touchscreen responds. I close it, it is unresponsive.
This is the second screen I purchased. I had the same problem with the first assembly and returned it. When I replaced it with the second one, it didn’t make sense to me to return it because the part does work but for some reason, every single time I close up the phone, the screen doesn’t respond. The front facing camera works, the home button works when the device is closed. It’s just the touchscreen that doesn’t work when closed.
An iPhone isn’t supposed to be open with its guts exposed to work. I thought about keeping the cover plates off for the battery and front assembly cables but, in my mind, these parts serve a purpose and make me leery that the phone will malfunction even more so than before so I put them back where they’re supposed to be. What could be the problem? Any assistance will be appreciated. Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I’ve had this problem before and 100% its the touch flex cable. It’s quite possible that you have gotten faulty parts, It’s happened to me before that multiple parts have been faulty. On the other hand make sure you are lining up the cables correctly when installing the back plate. If they are out by a little bit it can cause a sharp bend in the flex causing the touch issues you’re having. The cables on the third party screens are very thin and easily damaged so just make sure they’re lined up correctly and that you’re not applying too much pressure when installing the back plate.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
T.A.U. estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 13
