My Kindle has ghost touch
Like others my beloved Kindle Fire HDX 8.9”, purchased in June 2014, has developed “ghost touch”. I presume I need to replace the screen. :(
How can I tell which replacement part to order?
Es esta una buena pregunta?
Hi @dschuler5949 ,
Hopefully I have the information that you need.
According to this link depending on when your model was made in 2014 you either have a Fire HDX 8.9” 3rd generation or 4th generation.
If it is a 3rd gen, then I think that the model number is a GU045RW. Hopefully this may be found somewhere on the device (back cover?) to verify this.
If it is then here’s a supplier. Please verify with the seller first that it is a touch screen if you decide it is correct for your device and decide to purchase from them.
It was found by searching for GU045RW LCD digitizer screen. There were other suppliers but they all had no stock or sold out.
Here’s a link to the ifixit Kindle Fire HD 8.9" Display Assembly Replacement guide that may help.
Amazon have made it really difficult with their Kindle models to identify the exact model etc so apologies if this isn’t correct.
Fue útil esta respuesta?
Hi David.
it may very well be your digitizer is going on the tablet. check this out
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 28
Todo El Tiempo: 1,494
4 comentarios
I have been told by a repair shop that the replacement part is no longer available. If I must go into the used market it makes identifying the exact part I need all the more urgent,
Please help!
- de David Schuler
@dschuler5949
What is the model number of the tablet?
Here's a link that may help.
Having the exact model number ensures that you will get the correct replacement part.
- de jayeff
The serial number is B0180706349706JK. The "Type" (according to my Amazon devices) is Kindle Fire HDX 8.9". The link above says that's a Kindle 8 and that the serial numbers of Kindle Fire HDX 8.9 made in 2014 are unknown.
- de David Schuler
@jayeff The serial number is B0180706349706JK. The "Type" (according to my Amazon devices) is Kindle Fire HDX 8.9". The link above says that's a Kindle 8 and that the serial numbers of Kindle Fire HDX 8.9 made in 2014 are unknown.
- de David Schuler
