Saltar al contenido principal
Teléfono de gama media lanzado en septiembre de 2019. También llamado Redmi K20 Pro en China e India. Cuenta con pantalla Super AMOLED de 6.39″, chipset Snapdragon 855, batería de 4000 mAh con carga rápida de 27 W, lector de huellas dactilares debajo de la pantalla, cámara selfie emergente motorizada y una cámara principal con 48 MP más un teleobjetivo ultra ancho de 13 MP y 8 MP.
Preguntas 20 Ver todo
Can't remove front screen (even with heater)
Hi !
I have a xiaomi mi 9T (not pro but it’s the same they say).
I followed many videos, everything is fine, but i can’t remove the front screen, i heat, i went to 80°c on the front screen and it did not moved. It’s like the glue won’t melt. Do you have any idea ?
I already checked if there was any screw i forgot or thing like that, but there is not.
I really don’t understand why it work on their video and on mine it doesn’t
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You should try to pull it with a suction cup to create a gap between glass and frame, then operate with a tool to detach it.
Fue útil esta respuesta?
Puntuación 0
3 comentarios:
I'm trying but i'm not succeeding, i have a crappy suction cup and it's hard to hold the phone while pulling, but even when trying it doesn't seem to move, the suction cup just "unstick". Do you have some tips ?
- de
If the screen is already broken, go for a brute force approach but be careful with the frame. Sometimes a little of isopropyl alcohol helps to soften the glue.
Try to open even a small gap between the screen and the frame and spill some alcohol drop in it then wait a couple of minutes.
- de
Bruteforcing worked, i "digged" with a screw driver, then focused the heat on the broken part, and i managed to slide a thin tool between, then i heated the next part, and went under, until i removed the whole screen.
Thanks a lot !
- de
Añadir tu respuesta
Larry Pdb estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 7
Todo El Tiempo: 402
