replacing screen adhesive strips
do you attach the 3M strips to the glass or case,
And is there a guide to the placement of each strip
Es esta una buena pregunta?
I had huge problems after replacement to fix the frontpanel well. Maybe because of this the gave me two sets of adhesive tape... So anyway better to use two layers of the 3M tape if available...
My final solution after bad sticking frontpanel was at the end to use silicone sealent... now it sticks perfect and works also as a good sealing for dust...
Fue útil esta respuesta?
What kind of silicon sealant?
Here is the guide:
http://ipadscreenrepair.com/repair-guide...
Scroll down on the page for adhesive diagram.
here is the placement of the pre-cut 2 sided tape for ipad 2
[http://www.ipadscreenrepair.com/wp-conte...
it is very cheap and easy...
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 44,179
2 comentarios
Replacing screen
- de martinezramon974
martinezramon974 do you need help? if so please post a detailed Question on the question form
- de Jimfixer
