Saltar al contenido principal
La cuarta generación de la tableta Surface Pro, lanzada el 26 de octubre de 2015.
Preguntas 206 Ver todo
Backlight comes on, but no display after changing battery?
I just replaced the battery in my old Surface Pro 4. After reassembly, the device powers up and the backlight comes on, but nothing comes up on the display. I have connected it to an external monitor and confirmed that it is booting to the OS. I have also confirmed that the touch functionality is still working, by mirroring the main display with the external.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
If I’m not mistaken, when you disconnect and reconnect the battery in certain surface models, it blows a fuse for the image circuit. That or you could’ve damaged the display.
Fue útil esta respuesta?
Puntuación 0
Have a detailed look at the connector under the microscope. I‘ve had no touch and found a stucked pin inside the connector on the board. Maybe this is the same with your connector.
Puntuación 0
Did you solve your problem?
I'm having the same issue, i get a subtle backligth but no image. Maybe related to a damaged ribbon flex cable?
Puntuación 0
Añadir tu respuesta
Terry Laurent estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 77
