Is it worth adding the 2nd hard drive in place of the optical drive?
I’ve got the 500gb ssd arrived and just waiting on the rest of the bits to arrive but I’m wondering whether it’s worth removing the optical drive and replacing with the original mechanical hard drive if I’m fitting the 500gb ssd where the original drive was located? Or is it worth doing the conversion and when I can adding the 2nd hard with another ssd?
Es esta una buena pregunta?
2 comentarios
First make sure the SSD you ordered will even work in your system before you open the package! Your system only offers SATA II (3.0 Gb/s) SATA ports!
Your systems specs: 15" MacBook Pro Core 2 Duo (Unibody)
- de Dan
Hi Dan I got it from iFixit in their upgrade system so if they've sent it to me then I hope it'll be fine otherwise it'll be going back. According to the samsung site you are correct it does run Sata 6 but is also compatible with Sata 1.5. This is all new to me so forgive me if some of it goes over my head as I would have thought that if I've given them the info why would they send out an incompatible drive to myself?
- de kain.harkins
