Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 262 Ver todo
SSD no longer recognized after Disk Utility erase
I have a 15” late-2016 MacBook Pro that I had used daily since I bought it in 2017. I was trying to wipe the drive as I had just sold it online, so was following Apple’s online guide to preparing it for sale. https://support.apple.com/en-us/HT201065
I got to step 7 and followed the instructions here to erase the drive. https://support.apple.com/en-us/HT208496
When disk utility finished, it restarted and showed a circle with a line through it. Being somewhat tech savvy, I booted into internet recovery but found in Disk Utility there was no SSD listed. So I made bootable copies of Big Sur and High Sierra and loaded Disk Utility through those and still no device or volume listed. I tried using Disk Utility Terminal commands to see if anything was listed, and nothing was listed that should have represented the 512GB drive.
I can’t figure it out.. and the techs at Apple are bemused. Apple is now saying the SSD needs to be replaced. I literally followed their instructions, and now they’re asking me for $680 to fix it!? Is this a known problem with old Apple SSD’s, APFS, and Disk Utility? Does this sound familiar to anyone? TIA!!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
When you access Disk Utility from Recovery Mode, make sure Show All Devices is selected from the View menu. Also, can you post a screen shot of the results of running the following Terminal command: diskutil list
- de
Hi there. When made to 'show all devices', it still did not show the drive. Unfortunately Apple has the laptop now, so I can't post the diskutil list. But even in that, it showed only the boot disk, and a few other small drives, sometimes listing as much as 16-19 disks, but they were only about 50kB each. Not the 512GB SSD.
- de
Agregar un comentario
1 Respuesta
Might need to be repartitioned on another desktop.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
zadefaraj estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 61
