On PS4 DS: Left stick and L2 overlap each other
Whenever I press L2 the left stick claims to move forward! How can I fix this?
I initially thought that it was a dirt issue - that through whatever side effect the system would pick up soft forward motion on the left stick. After cleaning and no change in behavior I looked at the USB HID logs: In center position the left stick (ABS_Y) is at jitterung around 108 109 110 (the value range is 0…255) and the L2 - which is identified as ABS_Z is at zero.
Now If I swiftly press L2 the follow happens:
Event: time 1615892603.331589, -------------- SYN_REPORT ------------
Event: time 1615892603.335600, type 3 (EV_ABS), code 1 (ABS_Y), value 86
Event: time 1615892603.335600, type 4 (EV_MSC), code 4 (MSC_SCAN), value 90007
Event: time 1615892603.335600, type 1 (EV_KEY), code 312 (BTN_TL2), value 1
Event: time 1615892603.335600, type 3 (EV_ABS), code 2 (ABS_Z), value 13
Event: time 1615892603.335600, -------------- SYN_REPORT ------------
Event: time 1615892603.339612, type 3 (EV_ABS), code 1 (ABS_Y), value 84
Event: time 1615892603.339612, type 3 (EV_ABS), code 2 (ABS_Z), value 19
Event: time 1615892603.339612, -------------- SYN_REPORT ------------
Event: time 1615892603.343615, type 3 (EV_ABS), code 1 (ABS_Y), value 81
Event: time 1615892603.343615, type 3 (EV_ABS), code 2 (ABS_Z), value 24
Event: time 1615892603.343615, -------------- SYN_REPORT ------------
Event: time 1615892603.347616, type 3 (EV_ABS), code 1 (ABS_Y), value 79
Event: time 1615892603.347616, type 3 (EV_ABS), code 2 (ABS_Z), value 31
Event: time 1615892603.347616, -------------- SYN_REPORT ------------
Event: time 1615892603.351593, type 3 (EV_ABS), code 1 (ABS_Y), value 82
Event: time 1615892603.351593, type 3 (EV_ABS), code 2 (ABS_Z), value 39
Event: time 1615892603.351593, -------------- SYN_REPORT ------------
Event: time 1615892603.355607, type 3 (EV_ABS), code 1 (ABS_Y), value 81
Event: time 1615892603.355607, type 3 (EV_ABS), code 2 (ABS_Z), value 41
Event: time 1615892603.355607, -------------- SYN_REPORT ------------
Event: time 1615892603.359583, type 3 (EV_ABS), code 1 (ABS_Y), value 79
Event: time 1615892603.359583, type 3 (EV_ABS), code 2 (ABS_Z), value 56
Event: time 1615892603.359583, -------------- SYN_REPORT ------------
Event: time 1615892603.363586, type 3 (EV_ABS), code 1 (ABS_Y), value 75
Event: time 1615892603.363586, type 3 (EV_ABS), code 2 (ABS_Z), value 64
Event: time 1615892603.363586, -------------- SYN_REPORT ------------
Event: time 1615892603.367586, type 3 (EV_ABS), code 2 (ABS_Z), value 70
Event: time 1615892603.367586, -------------- SYN_REPORT ------------
Event: time 1615892603.371578, type 3 (EV_ABS), code 1 (ABS_Y), value 76
Event: time 1615892603.371578, type 3 (EV_ABS), code 2 (ABS_Z), value 79
Event: time 1615892603.371578, -------------- SYN_REPORT ------------
Event: time 1615892603.375607, type 3 (EV_ABS), code 2 (ABS_Z), value 86
Event: time 1615892603.375607, -------------- SYN_REPORT ------------
Event: time 1615892603.379609, type 3 (EV_ABS), code 1 (ABS_Y), value 71
Event: time 1615892603.379609, type 3 (EV_ABS), code 2 (ABS_Z), value 95
Event: time 1615892603.379609, -------------- SYN_REPORT ------------
Event: time 1615892603.383609, type 3 (EV_ABS), code 2 (ABS_Z), value 106
Event: time 1615892603.383609, -------------- SYN_REPORT ------------
Event: time 1615892603.387606, type 3 (EV_ABS), code 1 (ABS_Y), value 69
Event: time 1615892603.387606, type 3 (EV_ABS), code 2 (ABS_Z), value 114
Event: time 1615892603.387606, -------------- SYN_REPORT ------------
Event: time 1615892603.391578, type 3 (EV_ABS), code 2 (ABS_Z), value 116
Event: time 1615892603.391578, -------------- SYN_REPORT ------------
Event: time 1615892603.395576, type 3 (EV_ABS), code 2 (ABS_Z), value 120
Event: time 1615892603.395576, -------------- SYN_REPORT ------------
Event: time 1615892603.399605, type 3 (EV_ABS), code 2 (ABS_Z), value 124
Event: time 1615892603.399605, -------------- SYN_REPORT ------------
Event: time 1615892603.403600, type 3 (EV_ABS), code 1 (ABS_Y), value 67
Event: time 1615892603.403600, type 3 (EV_ABS), code 2 (ABS_Z), value 128
Event: time 1615892603.403600, -------------- SYN_REPORT ------------
Event: time 1615892603.407572, type 3 (EV_ABS), code 1 (ABS_Y), value 65
Event: time 1615892603.407572, type 3 (EV_ABS), code 2 (ABS_Z), value 136
Event: time 1615892603.407572, -------------- SYN_REPORT ------------
Event: time 1615892603.411571, type 3 (EV_ABS), code 2 (ABS_Z), value 143
Event: time 1615892603.411571, -------------- SYN_REPORT ------------
Event: time 1615892603.415601, type 3 (EV_ABS), code 1 (ABS_Y), value 66
Event: time 1615892603.415601, type 3 (EV_ABS), code 2 (ABS_Z), value 151
Event: time 1615892603.415601, -------------- SYN_REPORT ------------
Event: time 1615892603.419595, type 3 (EV_ABS), code 1 (ABS_Y), value 63
Event: time 1615892603.419595, type 3 (EV_ABS), code 2 (ABS_Z), value 155
Event: time 1615892603.419595, -------------- SYN_REPORT ------------
Event: time 1615892603.423598, type 3 (EV_ABS), code 1 (ABS_Y), value 61
Event: time 1615892603.423598, type 3 (EV_ABS), code 2 (ABS_Z), value 159
Event: time 1615892603.423598, -------------- SYN_REPORT ------------
Event: time 1615892603.427568, type 3 (EV_ABS), code 1 (ABS_Y), value 58
Event: time 1615892603.427568, type 3 (EV_ABS), code 2 (ABS_Z), value 166
Event: time 1615892603.427568, -------------- SYN_REPORT ------------
Event: time 1615892603.431566, type 3 (EV_ABS), code 1 (ABS_Y), value 59
Event: time 1615892603.431566, type 3 (EV_ABS), code 2 (ABS_Z), value 172
Event: time 1615892603.431566, -------------- SYN_REPORT ------------
Event: time 1615892603.435592, type 3 (EV_ABS), code 1 (ABS_Y), value 57
Event: time 1615892603.435592, type 3 (EV_ABS), code 2 (ABS_Z), value 181
Event: time 1615892603.435592, -------------- SYN_REPORT ------------
Event: time 1615892603.439571, type 3 (EV_ABS), code 1 (ABS_Y), value 55
Event: time 1615892603.439571, type 3 (EV_ABS), code 2 (ABS_Z), value 187
Event: time 1615892603.439571, -------------- SYN_REPORT ------------
Event: time 1615892603.443588, type 3 (EV_ABS), code 1 (ABS_Y), value 49
Event: time 1615892603.443588, type 3 (EV_ABS), code 2 (ABS_Z), value 197
Event: time 1615892603.443588, -------------- SYN_REPORT ------------
Event: time 1615892603.447587, type 3 (EV_ABS), code 1 (ABS_Y), value 48
Event: time 1615892603.447587, type 3 (EV_ABS), code 2 (ABS_Z), value 206
Event: time 1615892603.447587, -------------- SYN_REPORT ------------
Event: time 1615892603.451538, type 3 (EV_ABS), code 1 (ABS_Y), value 46
Event: time 1615892603.451538, type 3 (EV_ABS), code 2 (ABS_Z), value 212
Event: time 1615892603.451538, -------------- SYN_REPORT ------------
Event: time 1615892603.455584, type 3 (EV_ABS), code 1 (ABS_Y), value 43
Event: time 1615892603.455584, type 3 (EV_ABS), code 2 (ABS_Z), value 221
Event: time 1615892603.455584, -------------- SYN_REPORT ------------
Event: time 1615892603.459559, type 3 (EV_ABS), code 1 (ABS_Y), value 38
Event: time 1615892603.459559, type 3 (EV_ABS), code 2 (ABS_Z), value 231
Event: time 1615892603.459559, -------------- SYN_REPORT ------------
Event: time 1615892603.463560, type 3 (EV_ABS), code 1 (ABS_Y), value 31
Event: time 1615892603.463560, type 3 (EV_ABS), code 2 (ABS_Z), value 244
Event: time 1615892603.463560, -------------- SYN_REPORT ------------
Event: time 1615892603.467550, type 3 (EV_ABS), code 1 (ABS_Y), value 25
Event: time 1615892603.467550, type 3 (EV_ABS), code 2 (ABS_Z), value 255
Event: time 1615892603.467550, -------------- SYN_REPORT ------------
Event: time 1615892603.471558, type 3 (EV_ABS), code 1 (ABS_Y), value 17
Event: time 1615892603.471558, -------------- SYN_REPORT ------------
Event: time 1615892603.475574, type 3 (EV_ABS), code 1 (ABS_Y), value 8
Event: time 1615892603.475574, -------------- SYN_REPORT ------------
Event: time 1615892603.479584, type 3 (EV_ABS), code 1 (ABS_Y), value 0
ABS_Y first jumps down to 80 then even further, only if I simultaneously wiggle the stick I can counter this effect a bit. In the scenario above It ends with ABS_Y being 0, so the stick is claimed to be at maximum upwards position.
Is something miswired?
Es esta una buena pregunta?
