Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Las torres medias ATX tienen la misma construcción general y partes que otras torres de ordenadores de tamaño medio
weird issue as well with apex. When I click continue it restarts my co
I’m having a weird issue as well with apex. When I click continue it restarts my computer instantly and no error code pops up. Eventually I’m able to get in and this last time mid game it just restarted. So I threw in a new 1000 gold plus from evga and still get the same price problem.
On top of that I’m running into a whea-uncorrectable error. I did the disk check and ram check. Reinstalled windows. Mind you the computer is a prebuilt from nzxt that is maybe a week old.
asrock x570 pg4
pny 3090
64 gb royal
im waiting for nzxt to hit me back.
any ideas?!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Windows Hardware Error Architecture (WHEA) uncorrectable error indicates a hardware failure of some kind so start looking at hardware BUT it could also be a driver issue (!!!) or an overclocking setting.
  • I would first go into the BIOS and set to default but make sure to set the boot mode properly for your system - Legacy or UEFI.
  • Failing hard drive is a possiblity - may be intermittant from possible overheating, etc.
  • Failing RAM - again may be intermittant. Try swopping out one at a time in different slots.
  • Remove as much hardware as possible to try to isolate the problem
  • Don’t forget checking drives. I find IOBit’s Drive Booster (freeware) good.
That is a start. Let us know how it goes.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Johnny D estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 362
