Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2,2 GHz (Turbo Boost de hasta 3,4 GHz) o 2,5 GHz (Turbo Boost de hasta 3,7 GHz) con 6 MB de caché L3 compartida.
Preguntas 398 Ver todo
Screen not working after replacement - external display works
Hi,
I recently replaced my MacBook pro's battery. When testing my screen didnt work, i get a distorted image. I tested with external displays and no problems there, that works just fine. So i tried with a new LVDS cable first but the problem remained. So i tried with a new display and i still got the samen distorted image. Where to look now? Is the LVDS connector on my logic board broken?
Thanks in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
I would need to see things take a couple of picts of the distortion and post them here Agregar imágenes a una pregunta existente
- de
@danj I added a picture!
- de
Agregar un comentario
1 Respuesta
Well, somehow the display got damaged in the process. The T-CON board which is within the lid at the bottom of the LDC panel. A common thing I have seen in the last few years is the excessive cleaning has killed many! What happens is people use a spray cleaner directly on the screen to clean it without knowing it the cleaner drips down wetting the small T-CON logic board so it gets corrosion damage! Here’s a good writeup on how the T-Con works Sony T-CON Training Manual
You’ll need to replace the display assembly to fix this MacBook Pro 15" Retina Display Mid 2014 Display Assembly Replacement.
The bad news is finding one! Lots of people are holding onto the older systems as either they meet their needs or they just don’t like the newer system’s (butterfly keyboard) & (lack of ports and no internal expansion). Keep an eye here or do your own search using the P/N 2013/14 - 15” MacBook Pro Display Assembly, Apple P/N 661-8310
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Well, thats the weird thing; i already tried with a new display and the problem remains...
- de
Is it the same pattern or just black?
- de
@danj Thanks for your reply. Its the same pattern on another display.
- de
Are you sure you got a good display? Did you replace the full display assembly or just the panel.
If an external display works, with the external still plugged in is the internal display now working?
- de
@danj Yes, im certain i tried with a good panel. I replaced the entire display assembly. I even tested the current broken display on another system and it worked there. The external display works with the internal display on, but the internal display never works. It shows a distorted picture, no matter what.
- de
Mostrar 2 comentarios más
Añadir tu respuesta
Laurens Dierickx estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 40
