No touch screen after replacing the screen assembly, what's wrong?
Got the touch screen not working after replacing the screen assembly, here is what happened:
# Opened the screen cover easily, no problem.
- Try to remove the battery cable, but unfortunately disconnect the second port cable next to the battery port (I thought I did disconnect the battery cable, but I actually disconnect the wrong one, so, the battery cable is still connected with the logic board).
- Removed the old LCD type screen assembly, and replaced it with the OLED type one.
- Turn it on, everything works except the touch screen not functioning.
- Try to reset the phone, no luck.
- Try to enter into the recovery mode and do phone reset through Itunes, after finished, still no touch screen.
- Try to put the old LCD screen assembly back, but still no touch screen (it used to be working fine before this replacement).
- At this stage, I’m not sure if the logic board was damaged and causing the touch screen no longer working.
- Any comments? What should I do further?
- Many thanks!
Es esta una buena pregunta?
