problem with the phone unlock slider
hi, my screen has slight damage but has so for some time. the top slider works fine and so do the ipod controls when double tapping the round menu button. the issue is the slider now does not work, so i can see and hear texts and calls but i cant unlock the phone to answer or read them!
is there a way to unlock without using the slider, i dont have a password on the phone so fingers crossed. also is there a repair for this, the screen works partially, seems the problem is only at the bottom, would a restore help? many thanks
Es esta una buena pregunta?
4 comentarios
fantastic, i have had the case open which is not a problem, how would i go about repositioning the connector? ie which number connector do i need to reposition or what connector relates to the digitizer? kind regards
- de evan
and its an iphone 3gs white. regards
- de evan
no.2 is digitiser. Turn phone off first before repairs. I've edited this so that all the links on the right are for your phone. Good luck
- de pollytintop
thank you very much, somewhat of a guru and much appreciated and welcomed advice, i shall keep you informed kind sir.
- de evan
