Saltar al contenido principal
Lanzado en 1989 por Apple Computer, retirado en 1991.
Preguntas 24 Ver todo
Computer not booting after recap
I bought a Macintosh SE 1/20. It booted correctly from HDD but showed first signs of corrosion on the logic board. I recapped it and reassembled. Now it gives the boot chime followed by a happy mac. Then it starts reading from the HDD. Seconds later it gives a sad mac with error code:
0000000F
00000063
Can anyone give me a hint where to look?
Best,
Markus
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Did you replace the PRAM battery? Also check the socket sometimes the contacts are dirty.
You may need the 3.5” disks that came with the system to run the diagnostics.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Hi @danj,
Thanks for the reply. I did replace the PRAM battery. Checked with a system disk and I’m able to boot from a system 7.0.1 floppy.
Guess it’s a problem with the system on the HDD. Going to reinstall and check again.
- de
@mafo - Yep! Needs a new drive ;-{
- de
Añadir tu respuesta
Markus Forster estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 106
