problem with installing torsion spring on blade engagement rod
Model 42910x92a how do you install the torsion spring on blade engagement rod
Es esta una buena pregunta?
Your torsion spring is item #7 in the following image:
The S-Shaped end of the spring goes onto the frame as shown in the image above.
The other, L-Shaped end of the spring goes into hole in bracket #5, which is the “Lever Assembly Switch” (P/N 091917E701MA), Below is a pic of the bracket #5:
You can see the hole in the middle of the bracket.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 291
