Saltar al contenido principal
Una consola de juegos de televisión producida por Sony Computer Entertainment; La PlayStation 4 Slim (CUH-2000 Series) es un modelo de reemplazo más delgado para el PS4 original. Anunciado el 7 de septiembre de 2016.
Preguntas 566 Ver todo
Why I am getting every time that error: SU-41350-3
Hello, previously it had the other error code (SU-42118-6) when I bought it from seller, when I get the item and plugged in it throwing that message: Can not find the update file (SU-41350-3). I tried different usb drives 8 and 16gb size. downloaded reinstallation file and tried to reinstall, but after pressing ok (x button) it shows that error. is there any good solution? HDD has 100% health
Es esta una buena pregunta?
Puntuación 1
3 comentarios
I replaced HDD , both hdd has 100% of health. but still getting the same error
- de
I Think Tronicsfix should be good at this point. He would have experience
- de
Create a usb with exfat or fat32 partition. Create a folder structure PS4\UPDATE and place your PSUPDATE.pup inside it. Then Ps4 will recognize it.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Hi!
How is the USB formatted? Should be FAT32.
Also make sure you use the “Reinstallation file” and not the “update file”.
You should need this one: http://dus01.ps4.update.playstation.net/...
Guide: https://www.playstation.com/en-us/suppor...
Note: If nothing is working, just swap it with a known working hard drive. If that also fails, my guess is that something went wrong in the firmware…
Fue útil esta respuesta?
Puntuación 2
5 comentarios:
I did the same way several times, reinstallation file written on the fat 32 formatted usb drive. correct folder name. I replaced hdd with another one, but same problem . maybe the previous error code is in action?
- de
If that is the case, please read the following article: https://windowsreport.com/ps4-errors-su-....
They are telling "This error comes from a broken ribbon connector between your motherboard and BD-ROM". Perhaps replacing the ribbon cable can work, or the drive needs to be replaced. Worst case: Something is wrong with the drive's PCB or motherboard related.
- de
I have working one and will try . thanks
- de
No good news. I replaced the BR drive. also checked all ribbon cables connection between two side, they all beeped with multitester
- de
Perhaps it is firmware or motherboard related.. Motherboard looks good too?
- de
Añadir tu respuesta
Giorgi Mamardashvili estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 54
Todo El Tiempo: 1,703
