Saltar al contenido principal
Una consola de juegos de televisión producida por Sony Computer Entertainment; La PlayStation 4 Slim (CUH-2000 Series) es un modelo de reemplazo más delgado para el PS4 original. Anunciado el 7 de septiembre de 2016.
Preguntas 566 Ver todo
Power Supply Unit CUH-2102A PS4
Hello
my PS4 Slim beeps once and doesn’t turn on, I believe I need a new internal power supply unit. Does anyone know where I can purchase one I cannot seem to find one that fits the 2102A model?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi Brett!
You can buy them at Amazon: https://www.amazon.com/JEM-JULES-Replace...
(Also depends on the country your in).
Please remove the power supply first so you will see the ADP-XXXX model. Just to be sure that you have the correct one, there are many models available.
Note: This issue you describe could be power supply related, but also APU related. The best thing is to test with another power supply first.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Thank you that fixed it! Now it just won’t respond to controller only able to turn on via console
- de
Alright! Glad that it's fixed :)! Did you tried other controllers? If yes (and it's still not working as intended) please replace the antenna. Most of the time this is causing it (not always, could be many things, as example your bluetooth module). How to: Remplazo de la placa madre en el PlayStation 4 Slim (step 8 - 16)
- de
Añadir tu respuesta
Brett estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 112
