It appears that your console is parental locked. You can call Nintendo but that takes time so I’d suggest you use this procedure instead:
- Go to settings and see if you can get the parental controls prompt to pop up
- Choose forgot password on the bottom of the keyboard
- In the security question, choose forgot again
- Make a note of the Inquiry number
- Go to https://mkey.salthax.org/
- Choose 3DS
- Put the current system date (in case it’s wrong or something
- Leave Additional Data empty
- Put the number you made a note of above in the Inquiry Number field and hit Go
- Take the new number and put it on the number field on your 3DS
- The console should now be unlocked, go to the parental controls menu and disable it fully.
I hope this helps! If you have any questions feel free to report back (pictures of your screen are preferred so the community can understand better.
did you ever find a way around this? my 2ds has just done the same thing and i haven't got a scooby doo how to bypass this pin
- de haydentcity
Hi, i did provide an answer below a long time ago, let me know if it works for you.
- de Devnol
@devnol the issue is i can't physically access the ds to get to the settings, it's literally bricked on the "enter pin" screen even tho i have no idea what the pin is, it's a 6 digit combo with abxy and the dpad
- de haydentcity
@haydentcity Oh, i'm sorry. Black screen means your console has a pin set from some homebrew app, probably Luma3DS. I don't have a 3DS to test right now but either the NH Discord (at 3ds.hacks.guide) or the r/3dshacks subreddit will definitely be able to help.
- de Devnol
