My iPhone's Lightning Port Works, BUT Will Not Charge Once Turned On
I’m having the most bizarre problem.
My headphones work perfectly when I plug them into the lightning jack — they never get disconnected, or have any issue whatsoever. But when I unplug the headphones and plug in the charging cable, nothing happens!
I tried resetting the phone — no dice.
Next I tried plugging the charger into other iPhones and it worked immediately — so the cable isn’t the problem. Finally, I tried turning my phone off and plugging the cable in — within mere moments, the phone turned back on, so it is clearly recognizing the cable. Indeed, I turned the phone off with 33% battery and when it turned back on it had 40%, so the cable is working — and the iPhone’s hardware is still functioning — but for some reason the software seems to not recognize the cable whenever the phone is turned on and, therefore, I can’t charge my phone properly.
Any advice? What is going on?
Es esta una buena pregunta?
Have you already tried to reset or force restart the phone?
Maybe one pin in the dock connector might be dirt or corroded, you could try to clean it.
- de Jonas Geschke
