Saltar al contenido principal
timing chain position on sprokets
I have a 2001 Pontiac Grand Am 2.4L 4 cyln. Where to set the timing chain if its out of place?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Here is a diagram the shows you how it is all setup. Just wondering if you have ever done this kind of work before. It is very involved and not quite as easy...
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
+ And if you get wrong you could destroy the engine. I usually change the water pump at the same time--you have to remove it to get to the timing chain. And double check the sprockets.
- de
may I have that diagram too. thank you
- de
Respuesta Más Útil
@draccocain Carson, Dom, Below is the 2.4L 4 cyln. timing diagram. Good luck.
Puntuación 3
Añadir tu respuesta
Dom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 3,370
