Flashlight and magnifier app don’t work.
I replaced my rear facing camera, which solved the blurring and focusing problems, but now my Flashlight, Magnifier and Portrait mode do not work. Thank you!!
Es esta una buena pregunta?
The flashlight will typically disable itself if the phone detects a fault, are both cameras definitley working?
Fue útil esta respuesta?
I’m not completely sure. The camera works better in my IPhone 7 Plus,but Portrait does not work, nor does 1x. I can only take photos on 2x. I appreciate your thoughts, as I don’t know much about this subject. Is it possible that the replacement camera I received was defective or is this a different issue all together?
1x - does not work
Magnifier- does not work
Portrait- does not work
Flashlight does not work
yeah, if the 1x isn't working that will cause the others to stop as:
Magnifier uses both cameras
Portrait uses both cameras
Flashlight will disable itself if it detects a fault
New camera should work otherwise you may have a logic board issue
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 116
