Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.3, 2.6 o 2.7 GHz (Turbo Boost hasta 3,7 GHz) con 6 MB de caché L3 compartida.
Preguntas 577 Ver todo
Screen wont turn on after battery replacement
I have a Macbook Pro Retina Mid 2012 and I replaced the battery. After putting everything back together and verifying all items were plugged back in I charged the laptop backup. Upon pressing the power button, I get no chimes, and no screen. Its just black. The fans do start when the power button is pressed, the Caps Lock does work on the laptop as well. I dont have an external screen to test with so that makes it hard. I have tried a few resets including a SMC reset. Nothing seems to work.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Did you get the correct display? The Mid 2012/Early 2013 use a different part (different pinouts)
- de
Agregar un comentario
1 Respuesta
You dont have any TV screen nearby to check if the graphics unit work?
Maybe you damaged some cables trough your replacement?
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nathan Caudill estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 39
