Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Preguntas 1016 Ver todo
spilled tea on my iPod, what to do
spilled tea on my ipod, how can i get it to play? all i get is a black screen.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Is it a Classic iPod?
- de
Agregar un comentario
ABRIR TODAS LAS PESTAÑAS
Kits de actualización de RAM para Mac
Compra kits
Suficiente RAM
para todas las pestañas
Compra kits
4 Respuestas
Solución Elegida
awaesaeh, the first thing I suggest is that you turn it off, do not try to turn it on again, and follow this guide After you do that, replace the battery and reevaluate. You can use the step-by-step guides below the picture of the device, to disassemble. Rice will only work to absorb some of the liquid, but will not clean anything and will not prevent corrosion. If you do not clean the logic board etc, you might end up with issues like corrosion or battery failure later on.Good Luck and let us know.
Fue útil esta respuesta?
Puntuación 2
try putting the ipod in a bad with rice and leave it for a few days. if that doesnt work, the board is probably toast.
Puntuación 0
I left my ipod in my Mini ash tray with a open sun roof and found it under water after a rain storm.
I did not turn it on and put it in the oven at 150 degrees for about ten minutes, and then turned the oven off.
The ipod stayed in the oven overnight with the oven light on and in the morning the ipod worked fine.
Never turn on any shorted electronic devices.
Puntuación 0
place into a bag with rice. I am too chicken to even try the oven trick you mentioned.
Puntuación 0
Añadir tu respuesta
awaesaeh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 847
