My iPhone 6 when it try to charge it seems charging in phone. But not
When my i phone 6 try charge it seems charging in screen but not charging and it is restarting automatically in some times?
Es esta una buena pregunta?
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 4.7" es la versión más pequeña del iPhone 6 Plus. Identificable por los números de modelo A1549, A1586 y A1589.
Rep: 11
You should replace the battery to begin with. If it is still acting the same let us know.
Comentarios:
Baterry is new one
- de Namshil muhsin Ck
@Namshil muhsin Ck This is commonly called false charging. If you have ruled out the battery it can be caused by a faulty battery connector or charging IC. The most common is a faulty Tristar IC which will require microsoldering to replace. Since it is an iPhone 6 I would suggest an upgrade.
- de Chris Stables
Thanks.
If faulty tristar ic. Cost is too much for replace?
@Namshil muhsin Ck Around $90
- de Chris Stables
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 31
