Saltar al contenido principal
La versión más pequeña del Galaxy A20, el A20e mide solo 5.80 x 2.74 x 0.33 pulgadas y pesa 141 g. Ideal para aquellos que prefieren teléfonos más pequeños, este es un Galaxy que definitivamente cabe cómodamente en la palma de su mano, al tiempo que ofrece una pantalla considerable de 5.8 pulgadas gracias al diseño de borde a borde de la pantalla aprovechando al máximo el espacio disponible.
Preguntas 29 Ver todo
Wi-Fi low range after disassembly.
Hi I’ve a problem with my Samsung Galaxy A20e
I’ve managed to change the screen, but after that Wi-Fi gives me poor signal. It goes cool near the Wi-Fi source but if you make 2 or 3 steps away it’s gone.
I have:
-Resetted everything, installed updates.
-Changed 2 times the usb board.
-Changed coaxial cables. (white and blue)
-Changed Antenna Main Cover
-Changed Antenna-Sub Mea
Seems like problem is on the logic mainboard. Maybe I’ve touched or shortcutted something but I don't think so, it looks all cool and clean.
Can somebody help?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
This is a guess, did you possibly miss reattaching one of the component cables, like maybe the antenna wire that runs from the lower board to the upper board, the connector didn't fully snap in place during reassembly? To me it sounds like your describing a weak signal. Is your normal network signal for your carrier fine?
Fue útil esta respuesta?
Puntuación 0
Comentarios:
It is weak signal. Network carrier working fine, only problem is with wifi/bluetooth signal that works only very close to the source. Cables are fully snapped in place and everything else looks fine to me.
- de
did you solve this? I got the SAME thing!
- de
Añadir tu respuesta
Marco estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 79
