home button works but new digitizer doesn't
I’ve recently change a digitizer on my ipad mini 2 and the connectors look in good shape but i have a working home but no touch does anyone know why and what to do to fix it
Es esta una buena pregunta?
@ragecage005 could be a bad digitizer but you do want to double check your work. Make sure that the flex ribbon cables are properly routed, seated and not torn etc. Check the connector for bend pins etc. If all of this checks out okay get a new digitizer. If it should still fail you may have issues with the touch IC on your logic board which would require the help of somebody the does board level repairs
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 14
