Is there a digital relay to replace an omron g5le-1-vd Whirlpool front load washing machine?
Is there a digital replacement relay for an Omron G5LE-1-Vd mechanical relay?
Es esta una buena pregunta?
Double check your number again. It appears that I am missing your voltage on this relay with those numbers. I have not find anything commercial to replace this type of relay. you are truly looking at only a few dollars, whereas if you'd go digital your be looking at PIC controller as well as multiple other issues and would probably have to rig your own design. It will help if you let us know what washer this is.Good Luck
Fue útil esta respuesta?
The relay in question is an:
Omron G5LE-1-VD
12 VDC; Contact: 10A250VAC
2235W8
In my case, the washer requiring this relay is a Kenmore Elite HE4T.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 700
