Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
How can you recover data from a completely dead iPhone 4?
I have an iPhone 4 (or 4s don’t remember) that I used to use back when I was a teenager years ago.
I have lots of messages and photos that I’d love to see again, but I’m pretty sure the phone was water damaged. It’s never turned on either when plugged into a pc or charger.
Phone is completely lifeless.
Is there a way to recover all its data? Like, can I buy a working iPhone 4 and swap its motherboard or something?
Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
You mentioned that it may be water damaged, therefore to confirm this you should follow an ifixit guide to open up the rear cover and check the water stickers (red means water has got in, white means it is fine however these stickers are hyper sensitive and get red even with a bit of water vapour), if you have any tools to check the electrical flow on the motherboard after putting in a charger it would help, and later you may need to desolder the flash storage chip. Unfortunately these are simply my knowledge and I am not certified to do this kind of soldering work, so i am only able to help you up to here. I wish you good luck in getting your memories back.
Fue útil esta respuesta?
Puntuación 0
The storage is unfortunately on the motherboard, so replacing it would just give you the data of the iPhone that board came from.
Puntuación 0
Recovering the data required making the phone usable again, replacing a few individual chips that controlled functions like USB, touchscreen, and the display.
Puntuación 0
Añadir tu respuesta
Truzzie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 79
