Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
broke the "small antenna" during battery change procedure
During the battery change procedure, which went well for the most part, I broke the “small antenna cable” identified in section 17. Didn’t notice until reassembly. Since it is not the GPS nor the WI-FI antenna, I’m unclear exactly what I will find inoperative once I finish. Is a replacement available? (I was confused by the difference in picture between the Wi-Fi model and mine. Oh well.)
Es esta una buena pregunta?
Puntuación 0
Comentarios:
I’ve never used the Cellular capabilities of the mini 2, so will I miss anything if I do nothing? Will the mini constantly remind me that the antenna is broken? Note: I bought the cellular version to get the improved GPS capabilities.
I’m off now to get some 90% isopropyl to clean the gunk left behind from the glue.
- de
I don't believe so.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
It is the Right Cellular Antenna. With a damaged antenna, you will have less (or no) cellular sugnal.
Imagen de iPad mini & mini 2 Right Cellular Antenna
Producto
$9.99
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Leon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 41
