How to detach clogged hose
is there a way to detach the hose from the vacuum itself to get a clog out from the bend
Es esta una buena pregunta?
Hi @cefranzel ,
Here’s the ifixit Eureka EasyClean 71C Casing Replacement guide. This will help to open the casing so that the hose can be removed and cleaned.
At Step.6 in the guide the hose can be seen being held in position by being slotted into the case. You should just have to lift it out.
(click on image to enlarge for better viewing)
Fue útil esta respuesta?
thank you very much for taking the time to answer my question!
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 545
