iMac won't boot (probable bad PSU)
I have an iMac 21.5” (Late 2009 - EMC 2308) which won’t boot; completely dead. I believe the PSU is dead. I am hoping someone can confirm/refute that conclusion.
I searched for a pinout of the PSU but could find none. I followed the Apple Diagnostic workflow for “No Power; Dead Unit” with the following results at the Logic Board Test Points:
Test #1 - Pin #1 -> Pin #4 - LED #1 lights and 12vdc is detected when plugged in
Test #2 - Press PWR Button - LED #2 not lit, 0vdc at Pin #12 and no startup when power button pressed
Test #3 - Disconnected power button and tested for continuity - continuity is present
(also tried jumping PWR pins on logic board where button connects - same result)
Test #4 - Pin #1 -> Pin #11 - 12vdc present, whether or not power button is pressed
I conclude, from this, that the PSU is bad. If anyone has a pinout for this PSU (661-5299 or 614-0445) or can shed more persepective on this problem, I’d very much appreciate any insight that you can offer. In any case, thanks for the time and energy you spent reading this
Es esta una buena pregunta?
