Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Lanzamiento el 21 de septiembre de 2018. Modelos A1920, A2097, A2098, A2100. Disponible como GSM o CDMA/eSIM o nano-SIM/64, 256, o 512 GB/ Plateado, Dorado o Gris Espacial (Pronunciado "iPhone 10 S.")
Preguntas 201 Ver todo
Screen is half responsive and image shaking, what could be wrong?
The screen on my iPhone XS Max has the following symptoms recently:
  1. Touch screen is half responsive, which means sometimes fully responsive, but some times not responsive.
  2. image “shaking” or flicker, some times, not always.
here is the history of the phone, screen was damaged last December, so, I have it replaced in Jan. this year, (I have it replaced with the aftermarket part, not the OEM one from Apple). It works pretty good so far until those symptoms shown up few days ago. So, what could be wrong, the display becomes bad or the GPU on logic board might be the issue?
Any thoughts?
thanks,
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
It is most likely a faulty screen. You will need to replace it first before looking at the GPU. Do not buy an LCD screen, replace it with an OLED one and you shouldn’t have this problem again.
Fue útil esta respuesta?
Puntuación 1
Comentarios:
thanks for the comment.
- de
You must turn off the iphone and see if there’s any line in lcd under the glass and this image is the type of lines
make sure the screen is clean
Puntuación 0
Comentarios:
- de
Añadir tu respuesta
Tom estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 42
