Saltar al contenido principal
Ear Force PX22 es un auricular diseñado para proporcionar al usuario el sonido de juegos, música o películas, así como para permitirle comunicarse a través de varios programas de chat. Los auriculares fueron lanzados por Turtle Beach en septiembre de 2013.
Preguntas 10 Ver todo
My 3.5mm jack broke right at the top of the jack
ok so my 3.5mm jack wire broke right where the wire goes into the jack I cut it off and the wires are white with copper around it a blue wire wrapped around string and a red around string as well as a green one.. my question is I have a good jack I cut off my old Recon 70's and only matching wires are the white with copper around it the other wires seem to look like copper as well but with a clear sheathing over them please any help would be appreciated greatly
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@blazinghost the colors are not standardized. You will have to use a meter to figure out which wire is tip, ring and sleeve they go to on your Recon. Then you need to know which wire from your headset goes to the same location. Your PX22 uses a TRRS connector and the wires should be
Green - tip;
Red - ring 1;
White - ring 2;
Blue and copper twisted and soldered to - sleeve.
If you are confused about that post some good pictures of the wires, jack etc. with your QUESTION. We can always draw some pictures to explain this better. Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Bubba estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 40
