early 2013 MacBook Pro 15 inch
Model A1398 15 inch early 2013 macbook . I have a cracked screen. What screens will work for this? Or is there a way to make a screen compatible with soldering or changing components.
Es esta una buena pregunta?
Big Phil The Piper you’ll need Apple part number 661-7171. This is a beast to change that the display. I suggest you replace the complete assembly. ''MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement
Now could you make another screen fit. Possible but you would need to have the datasheet for your screen and then compare it to the datasheet of other ones. not an easy task to a. find it and b. possibly convert it to meet the requirements. It would most likely cost you more than the complete assembly.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 39
