Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La PlayStation 3 Slim es la segunda versión de la videoconsola PS3 con el número de modelo original CECH-2000. Producida por Sony Computer Entertainment, solucionó muchos problemas de la Playstation 3 original (gruesa). Salió a la venta el 1 de septiembre de 2009.
My PS3 won't turn on. No lights whatsoever.
I have a PS3 Slim (160 Gb) variant. 2 days ago I ordered GTA V. When i inserted the CD everything was fine. Proceeded to installing the game and at about 50% the PS3 just shut down with no beep or anything. When I connect it to the power cable, I can't see any red light or anything. It's as if it's dead. I looked up a lot on the internet for solutions and it's not YLOD cus there's no light at all. I opened it up too, cleaned it properly (it was very dirty lol) and it still won't turn on. Can someone please help me out?? (I took my PS3 out 4 days ago. My mom had stored it in a cabinet for a couple of months)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Respuesta Más Útil
It is most likely a PSU failure and/or some capacitor blown.
You need a multimeter and a new PSU (like this: https://www.ebay.co.uk/p/5007142744), or if you have a configurable power source you could use it to verify that the problem is the PSU.
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
Thanks for the quick answer.Will changing the PSU ensure that the PS3 will work fine like before?
- de
You should try another power cable, and power outlet just to make sure that the cable isn’t causing the problem. Since there is no light or any sign your ps3 is turning on, it’s either the cable the power outlet or the PSU.
Good luck
- de
There is no certainty, it could even be the motherboard burnt.
- de
Does your ps3 work now ?
- de
If it’s not PSU problem.then it may be motherboard issue
Puntuación 0
i have this issue and the wifi card shorted out
Puntuación 0
1I plug in the PS3 cables, the normal green light is on, a few seconds later it beeps twice and shuts down, please help. There were very important games, photos and job applications inside.
Puntuación 0
1 comentario:
I plug in the PS3 cables and the normal green light comes on after a few seconds. And it dosen't comes in the television please help i have Important photos games and things for job Applications
- de
Añadir tu respuesta
Mohammed Basil estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 67
Ultimos 30 días: 347
Todo El Tiempo: 15,235
