Is there a way to test charge port flex
Is there any way to test the charge port flex ? When plug in the test meter shows .47 and stays there . How can I determine if the charge port flex is bad
Es esta una buena pregunta?
Connect it to computer, does it register? There are Tristar/port testers you can plug in but first is it in DFU Mode? Will it go into DFU Mode/recovery mode if not and connect. If it is or can connect, will it restore or update without error? You can open it and test with multimeter as well…
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 107
2 comentarios
When you plug the cord in it sounds and shows charging then it goes away
- de Phil Pusateri
Thanks it did not respond when I plugged it into the computer so the charge port flex will need to be changed—Thxs
- de Phil Pusateri
