changed hdmi port, it cuts out when I move the wire
Twice this has happened. I replaced the hdmi port in an xbox one original. It works fine but if i move the hdmi cable the screen cuts out for a second but comes back on with the hdmi cable in the exact same position it was when it cut out. One of the ports i used was from ebay but the other was the unused hdmi in port from a broken xbox so it's not down to cheap parts. The port is obviously soldered in properly since it works and continues to work in the same position after it's cut out for a second so what could it be?
The most recent one i did had a working port to begin with (i told the owner that but he insisted i change it anyway because there was some visible damage) and when i moved the cable it didn't cut out at all. I don't understand why this is happening?
Es esta una buena pregunta?
