Hi @barmstrong ,
What is the model number of the dryer?
A Maytag F31 code means a L2 (line 2) voltage supply problem to the control board.
It could be a faulty hi limit thermostat, faulty heater element, wiring problem etc.
Do you have a DMM (digital multimeter) and know how to use it safely when testing for AC voltages, as you may need to do this, to find the problem?
Hi @barmstrong ,
Here’s the user manual for the dryer.
Go to p.5 to view how the electrical connection should be for the dryer. There should be 2 x 120V AC feeds to the dryer at the wall outlet.You should check there or the power box to make sure that all the fuses/circuit breakers are OK first.
Here’s a parts supplier for the dryer. If you click on Symptoms and then look for the No Heat symptom you will get the parts most likely and their location in the dryer, so that you can test them etc.
Be safety aware when testing for the voltage at the outlet. It is high voltage AC and it can be lethal if you don’t know what you’re doing
1 comentario
Thanks so much the people who answered. I have an electrician coming for my power problem and ill let him see your answers. Thanks everyone!
- de Beth Armstrong
