Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Procesador Intel Core i5 de doble núcleo a 2,5 GHz (Turbo Boost de hasta 3,1 GHz) con 3 MB de caché L3 compartida.
Preguntas 265 Ver todo
Wifi and bluetooth not detected + ports on right side not working
Model A1425
Macbook was dropped from <1m height and now says
  • “Wi-Fi: No hardware installed" and
  • “Bluetooth: Not available".
I have recently realised that the ports on the right side are not working either. This wasn't a problem before dropping it.
  • Usb port is completely unresponsive.
  • With the hdmi, the screen goes black for a second as if it recognises that the cable has been plugged in (this is usual) but then nothing happens.
I have done a couple of things to try solve the problem.
  1. Initially, I thought it was the wifi card. I took it to Apple and they “confirmed" that it was the wifi card that was faulty too so I replaced it. The problem wasn't solved.
  2. I also saw on two posts here saying it might be the I/O cable that is loose or broken. I tried taking off and re-attaching mine but it didn't help so I bought a new cable… but still the same problem.
Do I have to replace the I/O board or logic board now…?? I don't know what else I could do. I'm thinking I might have to replace the I/O board since the ports on that side have stopped working as well as the wifi card so surely if not the cable then it's the board that's the problem?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Replaced I/O board and now it’s working.
Fue útil esta respuesta?
Puntuación 0
Sounds like the I/O board cable has become dislodged or is damaged. Follow this guide to get to it Reemplazo de Cable de Datos de Placa E/S de MacBook Pro 13" con Pantalla de Retina de Finales de 2012
Puntuación 0
Comentarios:
Thank you. However, I mentioned in the post that I've already done this. I've decided to replace the i/o board on the right side so hopefully this will fix it.
- de
@el123 - Sorry, I jumped ;-{ Then its the board then.
- de
@danj Yep it worked! :)
- de
Añadir tu respuesta
Eli estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 45
