Why won't my MacBook charge?
My MacBook Air A1932 has stopped charging.
The charging port on the MacBook itself has minor black marks, almost like it got burnt.
Is there a part I can just replace to fix this?
Es esta una buena pregunta?
I would recommend getting an inline power meter to monitor your charger and your systems ability to charge. Here’s one: Satechi USB-C Power Meter Tester.
To replace the USB-C connector block MacBook Air 13” Retina Display Late 2018 USB-C Board Replacement and here’s the needed part MacBook Air 13" (Late 2018-Late 2020) USB-C Board
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 1,182
5 comentarios
Are you sure this is your model? Take a picture of the damage so we can see Agregar imágenes a una pregunta existente
- de Dan
Yes, I'm positive that's the model number listed on the bottom of the MacBook. When I plug in the charger it doesn't do anything but if I mess with the cable I'll get the red battery flash on the screen for a few seconds and then nothing. The MacBook will not turn on at all.
- de Bill
Have you solved this? Mine is doing the same :/
- de jhovanatrujillo
@jhovanatrujillo Yes, I was able to replace just the USB-C board (it was about $25 from iFixit) and it solved the issue for me.
- de Bill
@dollabillz217 - Don't forget to score and accept the answer!
- de Dan
