Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
Preguntas 124 Ver todo
Will not move belt seems good and no slop
Mower stopped moving can get to go forward or backward lifted off ground and tried it only one tire moves when has weight on it it will not go
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
SALTEA LA ACTUALIZACIÓN
Ahorra reparando con un kit todo en uno.
Compra Kits de Reparación
1 Respuesta
Check the belt going to the rear housing. Make sure it's on and tight. Make sure the fluid level is full on the rear differential. Don't try to put it in gear on its side. It has fluid drive setup on the later models. That's why you can slowly at speed or punch it nice and smoothly. Look at your owner's manual or if you don't have it give me the model and I can see if I can find it online.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Donald Lepley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 7
