Saltar al contenido principal
El Toshiba Satellite L305-S5946, con tapa Onyx Blue y pantalla LCD de 15,4 pulgadas, se lanzó en los Estados Unidos en 2009.
Preguntas 4 Ver todo
Why isn't my computer turning on when I turned it off while updating?
So one time I was on https://support.dynabook.com/support/mod... and I was searching to update my drivers on the Internet on my manufactures website and I chose to put in my computer model which is: PSLB8U-0JG037 and then I entered my model number and chose to update my drivers and software and then I went to the BIOS section and I I chose to update my BIOS and then it was downloading the file and I waited until I allow it to update it and then a popup screen popped up and it told me not to turn off my computer but I was so scared that I wanted to turn it off if this was going to do something bad to my computer but then I unplugged the AC Cable port off my computer and then I connected my AC jack back into my laptop’s port but it doesn’t turn on no more and there’s no light’s indicating that it’s turning on and I don’t know exactly what happened or I don’t know how to turn on my computer no more. Note: My computer only turns on with the AC Cable and the battery in my computer does not work no more but when I connect my AC cable into my computer it turns on the whole computer. Someone please help me find the solution to boot my computer up again because I don’t know exactly what happened to my computer or why it doesn’t turn on no more.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Sounds like the BIOS is now corrupt. By removing power from the computer, the BIOS is only half written. Without a proper BIOS, your computer will be unable to boot in any fashion. Unless the BIOS chip is socketed or you're willing to solder a new one, your only option is to replace the motherboard. If it says not to turn off, don't turn it off.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Albert estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 102
