I want to recell the laptop battery, new replacement expensive.
I wish to re-cell the CF-53 battery as purchasing a new one is just too expensive. Can anyone advice on how I should go about this exercise.
Es esta una buena pregunta?
Norman Stuart .. open plastic casing, take note of how the series is soldered together. buy replacement cells via google. solder them in series to match the old, resolder circuit board, place back in case, seal case.
Fue útil esta respuesta?
Many of my friends and clients think their Toughbook Battery Pack is no longer working properly.
But there is a "Utility" built-in every modern Panasonic Toughbook called Battery Recalibration.
It is model specific, but if you run this utility over and over at least five (5x) times, you will be able to
"Re-condition" your Toughbook Battery Pack and build-up the capacity of the battery pack.
As an example, if you have a battery pack that lasts 15 minutes, you may be able to condition it
back up to 45 minutes or maybe a little bit longer. To the best of my knowledge, only Panasonic out of all the
manufacturers offer this utility. Don't be skeptical, try this. It really works. And best of all, the utility comes
for FREE with every Panasonic Toughbook model. Except for your time. And you will not risk rebuilding a
battery pack and having it "explode" on you. LOL Good Luck from Richard, Montreal Based Panasonic Canada
Authorized Dealer since 1989.
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 165
