Saltar al contenido principal
El "phablet" insignia de la décima generación de Samsung, con su característico lápiz óptico S Pen. Lanzado en agosto de 2019.
Preguntas 27 Ver todo
What is the recommended solution for pixelation on the screen?
Right where the URL bar is when I'm using chrome or any other browser towards the far right there is a spot that looks like it's pixelated - a very small line that is at a 45 degree angle from the x axis and about a quarter of an inch thick. What parts should I buy to fix it and which tools will I need?n
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Can I get a picture please
- de
Agregar un comentario
1 Respuesta
It looks like the screen is damaged and will need to be replaced or you can live with it.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
How much would it cost to replace the screen ? Because I'm trying to sell it and it is perfect minus the small pixelation. Also I imagine I would need some special tools to accomplish the job, I'm am engineer but I work mostly in design but it seems like it would be straight forward (if time consuming) with the proper equipment. Suggestions? Also it should be mentioned that the area of the screen identified is the only problem area and often it will disappear and work fine. It never exacerbates the display issue and is confined to the small space identified.
- de
Añadir tu respuesta
Def Jaring estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 55
