Saltar al contenido principal
Repair guides and support for your Philips TV.
Preguntas 241 Ver todo
Why is "Channel up" on my TV remote jumping to channel 700 when press
Every time I press “channel up" it jumps to channel 700 (radio) regardless of what channel I start on. If I continue pressing it after that, it scans up as normal, until it reaches the first TV channel, and then it goes back to channel 70/ again. I have a 10 month old daughter, so I suspect she's pressed something on the remote. Everything else works fine.
Es esta una buena pregunta?
Puntuación 1
1 comentario
Hi,
What is the model number of the TV?
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Click ‘List’ (the button symbol is three horizontal lines, kind of like a cheeseburger symbol). Change the setting in the drop down from ‘Antenna Radio Channels’ to ‘All Satellite Channels’
Fue útil esta respuesta?
Puntuación 6
I found an answer, on my Mum's TV remote there is a language button, pressing it brings up the word English on the TV, pressing OK brings up a menu that defines the channels for the channel up and down buttons. Who knew that was there! It is very well hidden.
Once I found it fixing it was simple.
Puntuación 3
6 comentarios:
I've been pulling my hair out for weeks and you've only gone and sorted it for me, I would never have found that, worked 1st time, thank you so much Mandy.
- de
It's a terrible design to put that menu item there, glad you are fixed now.
- de
Thanks, you have given me the answer too
- de
Glad you are fixed too.
- de
Thank you - one of life’s frustrations sorted 😎
- de
Mostrar 1 comentario más
Thanks this helped for my Sharp Aquos Smart android TV, I had the same. Whilst in a TV or radio channel press MTS > language displays e.g. English > press ok then hit < left or right > until you see “all channels” at the top of the panel.
Puntuación 2
3 comentarios:
I have a Toshiba TV SUAZBe3DB and I have the same issue. Any tip please?
- de
I also have a toshiba and have the same issue, please help!
- de
I also have a Toshiba TV (only 2 months old) that's decided to do this, it's going through the window if I can't sort this, any help would be massively appreciated
- de
Channel changers generally have a favorites position. It may be in that mode now.
Puntuación 0
Añadir tu respuesta
David James estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 58
Ultimos 30 días: 299
Todo El Tiempo: 10,244
