Saltar al contenido principal
También conocida como "PS2", esta es una consola de la sexta generación de consolas para videojuegos, lanzada por Sony en Japón en Marzo del año 2000. Estados unidos recibiría su lanzamiento a finales del año 2000, con el modelo SCPH-3000. Reparar esta consola requiere simplemente herramientas comunes, de todas formas puede ser un poco complicado.
Preguntas 199 Ver todo
Why is my disc not spining
when i put my disc in i hear the lens move but the disc does not spin
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
shawn james, it is possible that the drive in your PS2 is worn out so that the disc 'brake' will not disengage. It is also possible that the door isn't recognized as closed. The "brake" looks like an eraser under the CD door that stops the disc when the console is turned off. The other problem could be the console is not detecting that the CD door is closed and thus will not spin up the disc to start. Of course then then there is always the possibility of a bad spindle motor, and I have also read that a bad laser/lens can give this problem too, but less likely. It would be more likely if you get a read error. Anyhow, at this time my suggestion would be to disassemble your PS2 and to take a closer look at what is going on. You can download the service manual from here and t I have an additional guide available here. I hope this will get you started in the right direction, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
shawn james estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,145
