Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
La Panasonic Lumix DMC-G7 es una cámara mirrorless de lentes intercambiables para principiantes lanzada en mayo de 2015. La cámara tiene una resolución de 16 MP y es capaz de capturar video en 4K. Los números de modelo son DMC-G7 en la mayor parte del mundo y DMC-G70 en Europa.
How much would it cost to fix the shutter on my Lumix DMC-G7?
The shutter sticks and the camera will not work. Does anyone know the cost for fixing this problem? Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Tried it myelf and failed due to several issues:
  • You have to dismantle the complete camera including several layerns of platines including the sensor.
  • The sensor is fixed by 4 tensioned screws (one at each corner). This means, these screws do not only keep the sensor in place, but by turning the screws you can tilt the sensor. As you must dismantle the sensor in order to reach the shutter, I'm quite sure you will need some special calibration tools in order to align the sensor properly. The alignment screws will be covered by the main platine so if you go with try&error for positioning the sensor, you will have to dismantle several platines incl. several flat cables each time you want to turn the alignment screws. That's where i damaged my camera completely
  • I managed to mobilize the shutter again without really identifying a root cause for the shutter to get stucked. No damaged parts or similar
  • I also managed to reassemble the whole camera with a mobilized shutter. But at high speeds the shutter was too slow. All images were way too bright, No problems at low shuter speeds though (>1/8s)
So all in all, there will be two main issues:
  • Shutter might have to be replaced completely - I did not find out where to get one from
  • It might be that the sensor has to be recalibrated
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Kat Salem estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 37
Todo El Tiempo: 1,139
