Saltar al contenido principal
Anunciado el 9 de septiembre de 2014, este dispositivo es la primera incursión de Apple en dispositivos portátiles inteligentes. Los manuales de reparación de iFixit son aplicables a Apple Watch (acero) y Apple Watch Sport (aluminio).
Preguntas 210 Ver todo
New screen coming loose.
I replaced the screen on my Apple Watch using the kit that included the force touch sensor in January. Everything was working fine. Recently (July) the screen came loose. The touch sensor is coming loose on both surfaces. The battery does not look bloated. It seems the adhesive is defective. What do I do now?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
You’ll need to get fresh adhesive Reemplazo de adhesivo en Apple Watch or the full Reemplazo del sensor Force Touch de Apple Watch
What likely happened is the surfaces were not clean enough. Either old adhesive was present or the solvent you use to clean the surface left a film which prevented good adhesion.
Sun screen and bug sprays can soften the adhesive so make sure you don’t get it on the watch.
Imagen de Apple Watch Adhesivo
Guía
Dificultad:
Moderado
1 - 2 hours
Imagen de Apple Watch Sensor Force Touch
Guía
Dificultad:
Difícil
1 - 2 hours
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
If the force touch sensor is loose on both surfaces, can you still do the adhesive replacement? The guide shows the force touch still attached to the watch body and the adhesive being applied on the display side.
- de
Its a sandwich: adhesive - sensor - adhesive
Its a matter on what failed the display side. or the case side, or both!
- de
I bought a new force touch sensor from ifixit. I cleaned the surfaces of the watch body and screen scrupulously using isopropyl alcohol.
There was absolutely no residue on the surfaces. I even used disposable gloves to prevent skin oils from contaminating anything. After installing the new force touch sensor, I wrapped it in rubber bands and let it sit overnight.
The next day after wearing it for about three hours, the screen started to come off again.
- de
What was the grade of the isopropyl alcohol?
Did you contact the iFixit store to see what they said?
- de
Añadir tu respuesta
John Tondora estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 194
