Mac mini 2011 won't boot and vertical lines.
My macmini is suddenly got verical lines on screen. And then problem with start up. I cannot go to recovery Mode. I can go to safe mode. But i don’t know what to write there to be able to go to recovery mode again. When i go to recovery i see the globe but after the indicated time is finished the screen turns to white. Can anybody please help me what to do? Thanks in advance.
Es esta una buena pregunta?
6 comentarios
Can you tell us which model you have Apple produced two versions:
● Macmini5,1 - HD Graphics 3000
● Macmini5,2 - Radeon HD 6630M GPU
- de Dan
Hello Dan, thank you. Can you please tell me where can I see that.? Because I cannot go to the computer. It can not boot correctly. I have the box. The model is A1347. Is it this one? Or can I see it from the safe mode? Please help me on this. I am not very familiar with apple.
- de Macminime
Locate your systems S/N from the system and plug it in to here EveryMac - Lookup
If you can get into Safe Mode then look at the About This Mac and then click on the System Report button click on the Graphics/Display section you should see one or two Video Cards listed.
- de Dan
I have the box. On the box i see that the s/n begins with CO
Macmini is 2.5, BEL/IEA. Can these information be needed to see the graphic card model. I will also try to single user mode (control s) to give you more details. I also did a hardware test that said no hardware issues found. Is that a good sign or not. Idk. But still vertical lines appearing and no recovery mode able. I appreciate your help.
- de Macminime
Command s and i see just bunch of lines (like dos in windows) and then i have to write syntax language. My question is if i cannot solve the problem with syntex, which syntax command should i write to have at least the recovery mode back? Is that possible? Because i have no access to recovery or whatever but this. Thanks in advance
- de Macminime
Mostrar 1 comentario más
